BeerCan
Tá mé ar meisce.
A few from the collection I just happened to take a pic of several months ago (sorry for the grainy pic)....
Up front are a pair of Threshold s/300's, each have been modded with higher value output caps, upgraded rectifier and bypass caps.
In between the Thresholds is a Tube Audio Design TAD-60. This can also be used as an integrated and has adjustment for output and global feedback. It can use a variety of tubes and is pictured here with KT-88's. It can be switched to ultralinear or triode operation and can also be biased down to a class A single ended triode (not a true SET, but friggin' sweet sounding just the same!). I love this amp. So much so I added a second one to the collection.
On the bottom of the rack is a Phase Linear 700B which is currently out for White Oak mods.
Above that is a Tube Audio Design TAD-150 tube pre and it can run 12AU/AX and AT7's tubes.
Above that is a Rega DAC which has been sent to another owner (and replaced with a Schiit Gungnir).
And to the left of that a Hafler 110 which has been given a host of upgrades (just in the rig at the time of the pic to do some testing in mono).
And sitting atop the Hafler is the best SS preamp I've ever owned, the Acurus RL11 which has had the board practically gutted and repopulated with better bits and had the power supply upgraded and moved to an outboard device....all performed by AK's resident Acurus/Aragon guru Mondialfan.
Wow I bet that system sounds great. Is that the setup you used to try the LS50's?
