wyn palmer
Addicted Member
In 2013 Hypnotoad designed the excellent AD797MCpre which has been built and used by numerous DIYers over the years.
This takes that original design and adds various refinements to improve noise, overload characteristics and RIAA compliance, and to remove the 2.2uF coupling cap by including a DC servo function.
It also adds the circuitry needed to extend the original phono stage into a completely functional preamp with a record output, stepped attenuator volume control, >200kHz bandwidth and unconditional load stability while maintaining DC coupling throughout.
The preamp also performs well with a SMPS, eliminating the need for either batteries or transformers, even with an IEC socket being added to the case.
The phono stage has 63dB of gain and harmonic distortion at 1v output which is unmeasurable.
ALSO: the design has a modified BOM for a MM cartridge with a reduced gain of c. 43dB.
Schematics are provided, together with parts lists and a board which can be purchased. The board enables either a phono stage only or a complete preamp to be built.
Simulated RIAA nominal compliance is +/-10mdB and measured as less than +/- 50mdB, 20Hz-20kHz. Expected DC offset at the record output is <1mv, and <2.5mv after the 6dB output buffer.
The design has been constructed and measured, and it performs, with a SMPS, as expected, with low noise levels dominated by mains hum and spurs, due to the SMPS switching, at 100dB or more below a 1v output level.
The output sounds quiet, smooth, and detailed, and very listenable to, with a nominal 230uv @5cm/sec 1kHz cartridge.
Due to the constraints of the slightly unusual architecture chosen, the gain is fixed and cannot be readily changed, but the add-on warp filter board provides switchable 10dB of gain if needed.
Together with the preamp board there is a secondary board which holds the extra power supply decoupling components for use with the SMPS.
The boards are designed by another Audiokarma contributor- HalfApt- and his enthusiastic efforts are essential to this project.
The Drop box info (below) includes build notes (post #560).
https://www.dropbox.com/sh/4iwr55ql8ynmfnx/AADX2-izp3fJig0ZrnkxcJwTa?dl=
Below are extra links to the BOM for the warp filter and headphone add on boards. Later I'll add more information on the new add-ons.
Mouser cart for headphone amp:
https://www.mouser.com/ProjectManag...jectGUID=f6485585-7fff-45e5-8a39-0c3592d2fc62
Mouser cart for warp filter:
https://www.mouser.com/ProjectManag...jectGUID=c1b708b2-2d04-4880-911d-fe925d064ddf
Mouser carts for the v2.0 boards.
Pin strips for adapters
https://www.mouser.com/ProjectManag...jectGUID=96cd444a-da59-42b2-a14b-10d611a18d04
SMPS filter
https://www.mouser.com/ProjectManag...jectGUID=97f8516d-fe9f-49bc-bd16-4eca06a8cfb5
RIAA MM single specific parts
https://www.mouser.com/ProjectManag...jectGUID=9206d8aa-7d5d-472e-9b02-139b75a9e7ba
RIAA MM parallel specific parts
https://www.mouser.com/ProjectManag...jectGUID=baba71ac-4abd-46d5-b41b-e56b176f07a7
RIAA MC single specific parts
https://www.mouser.com/ProjectManag...jectGUID=e3dd6792-b6bb-4f33-8e07-28e7c6664064
RIAA MC parallel specific parts
https://www.mouser.com/ProjectManag...jectGUID=bd0ce5e8-f10e-4d43-a500-d2f1804f83dd
RIAA Common parts
https://www.mouser.com/ProjectManag...jectGUID=657da618-4f53-482d-9959-aa5992b8ab6f
I/O parts
https://www.mouser.com/ProjectManag...jectGUID=e104e74b-5a86-40c7-a96b-9891bc37ff63
Line-buffer parts
https://www.mouser.com/ProjectManag...jectGUID=18d257fd-9b8e-496f-ad41-f64b6d65c5ff
Warp Main board parts
https://www.mouser.com/ProjectManag...jectGUID=55D79F3B-C5C9-48A4-95FB-3FA59F420457
SMPS filter
RIAA Common parts
I/O parts
Line-buffer parts
