j!m
Use the standard MM gain configuration of 43dB SE, 49dB balanced for both high output cartridges.
It's not clear to me if you want a LO MC value as well. The standard configuration will provide 63dB gain SE, 69dB balanced, which should be acceptable for the 0.4mv output (also at 3.54 cm/sec 1kHz) or 0.56mv (5cm/sec) . This is c. 8dB higher than the cartridge that I use. The overload margin at miss-tracking will be c. 8dB, which should be OK.
OK I have plugged in 43 dB into the Gain Calculations excel sheet and I get R8 value of 28066.26 ohms and R9 value of 7267.07 ohms. Therefore, I chose 28k for R8 and 7.3K for R9; (deviation is 0.09%) for 43.02 dB calculated overall gain. 28k is easy enough to find, but on Digikey anyway, the 7.3k is a bit harder to get. Is this value typically stocked with other vendors? And did I calculate correctly before I dig for something I can work around?
Thank you again.
