Is there something different about the dual idlers that make a high mass plinth unnecessary? There have been extensive posts here, at vinyl engine, lenco heaven showing beautiful examples of plinths that enhance the sound by acting like a sink for vibration and rumble. Would a table like the 1019 benefit? The 12 series? Thanks. Norm
I can't speak for the Lencos, but I currently own 4 idler drive tables: 2 Elac Miracords (a 40 and a 45), a Dual 1228 and a Rek O Kut B-12H. Based on the construction of each, it's very easy to tell they were originally intended for different applications.
The Rek O Kut was designed for broadcast applications and is built like a tank - especially the enormous and powerful Ashland motor. The ability to stand up to abuse and constant playing time, in many cases 24/7, was a requirement of the target market.
The Duals and Miracords were aimed at the less demanding home market. Not less demanding in terms of sound quality, less demanding in terms of the amount of use and abuse they would be subjected to on a daily basis.
By comparison the Dual and Elac motors look like toys next to the enormous, powerful Ashland motor of the Rek O Kut. The Duals and Elacs came with suspended chassis. The Rek O Kut was intended to be rigidly bolted to a broadcast console.
So, I suspect the reason you see massive plinths for Rek O Kut tables is to dampen the vibration of the much larger, more powerful motors. This is where the smaller motors of the Duals and Elacs have an advantage. They require far less to dampen any vibrations from their drive motors.
I don't want to generalize too much, since I don't have a Lenco, or other broadcast table to compare to my Dual and my Elacs, but in my particular case, it's not hard to see why the Rek O Kut would benefit much more from a massive plinth than my home market Dual and Elac models.
