High-ripple filter caps for SW Power Spply
The Nichicons are quite nice. Matsushita/Panasonic low esrs are very good as well. :yes:
Cheers
Lar
Thank you for the reply. This one is low ESR and low inductive as well. I happened to find the retailer shop I visit often sells them. They are probably not available anywhere else, though.
Any time you replace old filter caps its not too surprising that it will sound better. Even if you replace them with common nothing special about them capacitors, just having full power supply capacity can't possibly hurt things. The sound you hear ultimately comes entirely from the power supply, so if its not working at its best, then nothing else will either.
