The ST-S444ESX shares a service manual with its mostly-identical European sibling, the ST-S700ES. Our contributor Brian Beezley offers this review: "The ST-S444ESX is part of Sony's high-end ES audio component line. It is a good-looking, black AM/FM digital tuner in an all-metal enclosure. It has wide/narrow IF selectivity and a number of bells and whistles. Unlike some earlier ES tuners, it uses ordinary RCA output jacks. The front panel proclaims 'Extremely High Standard' and the user's manual offers these remarkable specs: 1 kHz THD of 0.005% in mono and 0.0095% in stereo for the wide IF mode, and 0.04% and 0.07% for narrow. The same figures are specified for IM distortion. The signal-to-noise spec is 96 dB in mono and 91 dB in stereo. The other specs are less remarkable but excellent. The circuit features a single RF stage with three tracking resonant circuits before the mixer, which uses a single 3SK74 dual-gate MOSFET in a Micro-X package. I was surprised to find no evidence of RF intermod in my high-RF location with the unbalanced mixer circuit. The IF has two 250 kHz MX GDT filters in wide, plus two 180 kHz filters in narrow. The IF uses 'Wave Optimizer' technology, which compensates for IF group-delay distortion. It consists of two adjustable transformers and a trimpot, with separate circuits for mono and stereo. The detector is a phase-locked loop, which offers the highest S/N ratio of any detector, although not the inherent linearity of a pulse counter. The PLL has a distortion adjustment.
"The stereo decoder uses a 28-pin Sony CXA1064 chip that has a pilot canceller and individual left- and right-channel separation adjustments, and requires no 19 kHz adjustment. Memory is maintained by a 0.039 Farad capacitor. The tuner has another trick circuit called 'Super Sound Tracing' that modulates the front-end varactor tuning voltage to minimize distortion. This circuit automatically engages and lights a panel indicator whenever the input signal is greater than 35 dBf in the wide IF mode. It has one adjustment. The frequency synthesizer uses a Sony CX-7925B chip, which requires no prescaler. Sony calls this a 'Direct Comparator' and used it in many of its digital tuners. Unstuffed on the PCB, which is marked ST-S333ESX [a tuner sold in Japan - Editor], are components for long-wave reception. I'm not into fancy capacitors, but for those who are, there are 10 Nichicon Muse capacitors scattered throughout the detector, audio, and power supply circuits. I'm also not particular about op-amps, but the one used in the audio-output stage is a JRC 4560. The tuner has an unusually large power transformer. The power supply regulators use PCB-mounted heatsinks, one rather large. Line voltage can be 120V, 220V, or 240V.
"I like high-end Sony tuners and I liked this one, even though I could not get it to meet its extraordinary specs. The problem was that distortion varied with signal level. Tweaking the IF compensation circuits, I could reduce distortion to very low levels, only to see it rise if I changed the input level. THD varied between 0.3% and 1% at low signal levels in wide IF mode, but at more usual levels it was typically < 0.1%. THD was 0.45% in narrow with a pair of 110 kHz filters replacing the original 180s. The tuner had audible background noise when receiving HD Radio signals with the wide IF filter. Installing a postdetection filter quieted it. With the modifications, I measured mono sensitivity as 20.5 dBf in wide and 21.4 dBf in narrow, and stereo sensitivity as 39 dBf in wide and 39.9 dBf in narrow. These numbers are typical of what I measure for high-quality tuners, although worse than spec and a few dB behind the most sensitive tuners I've come across. The 110s yielded adjacent channel selectivity of 43.5 dB, which is an excellent figure and really useful for digging out weak stations next to strong. The ST-S444ESX normally tunes in 50 kHz steps. This is too large to avoid adjacent-channel interference by tuning off-channel, and it requires four button pushes to reach the next channel, making manual station scanning a real chore. You can convert to 100 kHz tuning steps as follows. In the lower left-hand corner of the PCB, look for a cluster of diodes. Clip one lead of the diode marked "50/100." The microprocessor reads this diode on power-up, but only when the 9/10 kHz AM-spacing switch on the bottom of the chassis has changed. Change the switch, turn on the power, turn it back off, restore the switch, and you're done."
