tony.goodwin
Hi. I have had this tt from new. It’s been in its box for a few years and was sporadically used during the cd era. I want to use it again as I still have a lot of vinyl, some emotional.
It works, almost. Sound ok (but, below…), mechanism fine.
It’s direct drive, uni-torque.
Problem: uneven speed and strobe not stable. Seems to wow once or twice a revolution.
Reading other posts I have cleaned up the bearing and oiled with 3-in-1. I am sure that it’s running freely enough, but welcome thoughts. The ball bearing has a little wear in the shape of the contact circle to the cup, but I have positioned it to avoid that being in contact on reassembly. Red herring I think, BECAUSE
After a while (a side or two of an lp) (and after some additional rebuilds as well as cleaning the platter and the reflective segments that had tarnished) it would eventually synch and then was 100% stable (no wow, strobe solid)
But, after switching off and leaving it a bit 30 mins or longer) it went back to wowing.
I left it running all night on repeat (volume down!) to “run it in” which got it stable and then played it all day today, fine.
I stopped again for an hour and after picking another disc the trouble was back. This time it stabilised in the first side. But I want it to work from the start!
What to do? Could the fault be electrical? I read about cleaning pots, but why would that work? 33/45 switch works fine.
Or capacitors? I could do that I guess but do they “warm up and start working” like I am observing?
It’s making a lovely sound now. But will it still love me tomorrow?
Help please?
Help please?
