Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I put the SC458s back in, one of the 2240s was definitely a dud because now it works as if I hadn't touched the unit in the first place. I checked Q801 and 802 and sure enough the middle joint on 801 was almost as if it was not even soldered in and 802 had a bad joint on one of the outer pins. After adding some solder to these two joints, the noise floor is greatly reduced. At a volume of 2 I have to put my ear against the tweeter to hear it, and at full volume it is only heard a couple feet away.
This receiver is made with the HA1452W, kind of op-amp. Some become noisy with time. I've seen that they can be very noisy in the first 10 minutes of operation and then the noise floor reduces to acceptable level.
