Hi All,
Working on a Hitachi SR 604. All squared away and sounding good with the exception that
there is no FM stereo. FM mono works well and gets lots of reception.
Tuner uses the Hitachi HA 1196 chip. Identified as IC 301 on schematic. All dc voltages on chip are within reason with the exception of post 16 {VCO area} which reads an acceptable 4 volts in mono and dips down to 2.2 v in stereo. Messed with the VCO and Separation variable resistors with no effect. Put them back where they were originally set. C 310 matches the pin 16 readings.
I tested the AC voltages {for signal} on the pins and when switched into stereo both the output and INPUT
voltages went to zero. I have a scope and would think it would show the same results.
I am guessing the signal which is there at the input in mono is getting dumped to ground in stereo. Anyone have an idea where this is happening? Inside or outside the chip? Any info will help.
Thanks
Thanks
