Hi all,
I have a Harman Kardon 450 that I really like, but I've always felt that the left channel is kind of weaker/thin than the right, reading up on DC offset and Bias I finally gathered some courage to give it a try to adjust the DC offset for the first time.
The trimpots were a bit flaky but managed to get both channels down bouncing between -4mV to 4mV after 15 minutes.
I also noticed that the Left channel had been worked on, one of the two output transistors had been replaced and also the Left Bias trimpot seemed to been replaced.
Next I followed the service manual to measure the Bias and according to it the Bias should be measuring 33 mV however when measuring this is what I got:
Left Output transistors:
Nec D587 (not A) & T B688 (This one was the replaced one)
Measuring 12 mV across emitters
Right Output transistors:
Nec D587A & Nec B617A
Measuring 3.5 mV across emitters
I actually thought the Right channel have been sounding good but after seeing the measurements I started to wonder if it´s way off of what it should sound like?
Also is too low Bias bad for the speakers?
Since the Dc offset trimpots were a bit flaky I'm not sure if I should try to mess with the Bias trimpots, is it really necessary?
Edit in 2021: After one year I've become a bit wiser, please DO NOT attach the probes as my depicted picture down below. HK450 service manual states to test at Emitters and I´ve seen others mistaken this as well, but at page 8 "Alignment Points" it clearly shows that they meant the Emitter resistors. Well live and learn
Oh, English is not my native language so please excuse any mistakes.
Thank you.
Thank you.
