hk 670 receiver help
orsen
Jukebox Hero
i picked one of these off the curb some time ago, the power switch has been bypassed as its broken.
the switch is damaged beyond repair :(
reciever seems to work fine otherwise.
the switch is an alps m-085.
anyone know of a replacement?
thanks
If there is enough room behind the panel, you might be able to replace it with a standard old style AT PC power switch. Do an ebay search for
AT computer power switch.
Rick
thanks
you were right
i found an alps TV-5 in a pc
the original switch says TV-6 i can find no ratings for it at all
i can find ratings for the 5 its 250v @5a
think i can just interchange them and the matching arc capacitor?
Yes, should work fine. Usually, the rating is printed or stamped on the switch body. You may need a magnifying glass and light at just the right angle to read it.
Rick
