Define LPF please. There's a 0.22uF cap between those pins.LPF on Pins 8 and 9?
No. just listening to a strong stereo station and hearing it kick in. But I have a 100MHz scope and would like to know how this test is done. I don't have an FM stereo generator though.How did you verify you have stereo coming out of this thing in FM? Tape out with a scope in X/Y mode?
I selected one from spares that lit at 8 volts. I didn't check its current draw though.Did you change that stereo indicator lamp? The one in the parts list says "6.3 V 40 mA". (earlier I said 8 volt, that was incorrect). If you need to drop the series resistor to 25 ohms to get the lamp to light, it is drawing **way** too much current. The Stereo indicator lamp output of the IC is current limited at 75 mA.
I think you said you replaced the stereo lamp. What did you use; voltage and current rating of the lamp? Maybe you have a 300mA lamp in there. Should be like 40mA.I tried this. No light. Tacked in a 1k pot from the light side of R302 to gnd. Light came on at around 25Ω.
How does the IC trigger the lamp driver? What external components that support this IC can I examine? It has a good power supply and there is 19KHZ on pin 10.
Another thing to consider is the right channel takes 1-2 seconds longer to come up than the left.
This is exactly what I just did. I opted for one with adjustable frequency output.Here's how you can get a FM stereo generator on the cheap:
Buy a FM Stereo modulator for use in a car. They are used to play a CD player or similar through your car's radio.
I have a Belkin that I use for alignment when I need a synthesized source to align a synthesized tuner. It will have a left and right input, so to adjust the separation, only connect one channel and adjust for minimum signal on the opposite channel.
Something like this will work.
https://www.amazon.com/Belkin-TuneCast-Mobile-FM-Transmitter/dp/B00008SB1D?th=1
What are you using to measure the frequency? You could be loading down the circuit. If you have a frequency counter and the input impedance is 50 Ohms, that is too low. Some of them have an impedance switch or alternate 1M Ohm input. Sometimes there is a 50 Ohm resistor across the input jack that you can remove. If your scope measures frequency, use that, with a 10X probe.This is exactly what I just did. I opted for one with adjustable frequency output.
I also have a HA1156 in my unit and the replacement i ordered is the HA1156W, but i cant get the pilot frequency high enough. it tops out at 18.8 khz.
I thew the tuning WAY out of wack chasing a ghost, and now im trying to get it back to at least play in stereo. Some of the adjustments have no visible changes on my oscilloscope, but the more i adjust, the worse it gets. The manual says it MUST be under .3% THD to work correctly if im reading that right. I have a marantz 2215B on my bench.
I was using an oscilloscope as a frequency counter, but it would display 19.0 kz, and was likely not high enough resolution. With this transmitter device I turned the source all the way down to just send the pilot signal and used some finesse. If i remember correctly i heard it "click" into place on my headphones.What are you using to measure the frequency? You could be loading down the circuit. If you have a frequency counter and the input impedance is 50 Ohms, that is too low. Some of them have an impedance switch or alternate 1M Ohm input. Sometimes there is a 50 Ohm resistor across the input jack that you can remove. If your scope measures frequency, use that, with a 10X probe.
Failing that, you can tune to a known good station and adjust the PLL pot to the middle of the range where the stereo light comes on.
If none of that works, the IC could be junk or an external component may be bad. Pin 14 of the IC goes to components that set the frequency.
