Zeus12
Greetings fellow audiophiles,
Continuing with my partially restored HK 730 I decided to change the VR401 Variable Resistor (trimmer) since it was giving me issues and couldn´t get it past 13-18 mV.
I used a Bochen 3296 W102 13 trimpot as a replacement.
https://www.audiophonics.fr/en/trim...rn-trimming-potentiometer-1k-ohm-p-13012.html
I know it´s not the most suitable orientation but for that channel, I can still reach the turning screw through the 2 transformers. Now, for VR02 will be more difficult to access, so I´ll leave the original trimmer in there until Mouser gets some new stock. According to @jheu02 this is what I need:
https://www.mouser.es/ProductDetail/Bourns/3362W-1-102LF?qs=cdlJwygV6pmEKtalJFMnhQ==
I used the approach of @Skywatcher from here:
Underside:
There is another method, of "el Maestro" @dlucy here:
https://audiokarma.org/forums/index...arman-kardon-330c.781237/page-6#post-11943536
So basically this is just a simple "resistor" and needs only two legs. Does it matter which one I solder the middle leg (2)? Also is the orientation of the trimmer important? If I´m not mistaken, resistors are unaffected by orientation so it shouldn´t matter.
Unfortunately, the way it is now, is even worse than before. It is TOTALLY unresponsive and the Bias on the Right channel doesn´t go above 10 mV. I keep turning that little tiny screw and NOTHING moves on the DMM. VR02 works perfect and I can get it to the original spec of 35 mV +-.
Any ideas on what to do?
Cheers!!
https://audiokarma.org/forums/index...man-kardon-730-question.924705/#post-14015790Look close at the trimmers and board and you'll find the 3rd hole is already there along with the trace to solder to. A 3 lead trimmer is a drop-in replacement. Easy as pie.
Underside:
Cheers!!
