xrayspex77
My HK730 has a 40VDC (at Speaker Terminal) Spike in the L Channel when powering On. After about 5 mins it will settle to around 100mV. If I power off/on the spike is minimal. Discovered that unplugged I get 8VDC at the L Terminal until whatever Cap it pulling from is drained. R Channel is Good
Found these threads with similar issues
http://audiokarma.org/forums/index.php?threads/harmon-kardon-730-high-dc-offset.552435/
http://audiokarma.org/forums/index.php?threads/harman-kardon-730-issues.416189/
http://www.audiokarma.org/forums/index.php?threads/left-channel-issues-with-hk-730.372163/
I am going to recap the Amp Board and check the Trans in the L Channel. I have the subs suggested
(30) KSC1845FTA's (they don't seem to make the EBU's anymore) to match up for the 2SC1400's
MJE243G for the 2SD415
MJE253G for the 2SB549
I have removed the Heatsink/Amp Board which was easy.
Is removing the Heatsink from the Amp Board is as easy as removing the screws from the OP Trans or do I need to desolder the Legs from the Amp Board?
Thought I'd ask before I found the hardest way to do this, might save another relative noob some time
