audiodon
Addicted Member
Hi,
I've got a Citation II that had a mechanically buzzing power transformer that drives me to distraction.
There's not a lot of information I could find about unpotting and potting transformers, but I did find posts from chinacave, Dan055 and Battradio that helped.
So, I followed Dan055's advice and boiled up some water with the potted transformer in there, pulled off the bottom cover and, after a lot of noodling, finally got the transformer out. Then I boiled it some to get some of the potting goo out, and then put it in a dedicated toaster oven I have to dry out. But there's still a lot of this graphite-like potting material on the tranny, even after I've slit and pulled the paper covering the windings.
My plan is to give it a shellac bath and repot. That plan is subject to change though. I am concerned that the graphite potting goo will obstruct the shellac from getting in there and doing it's soaking magic. I like to soak it for a day while the shellac is warmed up to get everything nice and sticky and then dry, drain, and bake.
Here are some thoughts and questions.
1. I'm mulling over whether to just try and fix it or to do something else. These are supposed to be legendary transformers after all.
Does it make sense to send this to somewhere like Heyboer and get it mapped or is that already done? It's not broken, just has a mechanical buzz. There's always the possibility that I'll get something not as good back.
2. The potting stuff wasn't tar. It was much more like graphite. I couldn't seem to get it to liquid temperature, and extracting the transformer wasn't easy. Finally I got it softened enough to pull some out with a putty knife, allowing me to pulll out the transformer. The rest of it was scraped out and put in a bucket.
Any recommendations for replacement potting stuff and where to get it?
3. Any other suggestions or experiences that can shed some light here?
Don
Don
