sloober
I ordered a new belt for my ST-7 from turntable basics along with some silicone damping fluid. The old belt works, but I thought a new one might be in order. The old one is a yellowish clear, the new is black rubber. The new one is about an inch shorter. The old belt is slightly larger than the portion of the platter that it goes around, and would fall off if you looped it on and turned it over. The new one fits tighter and will not fall off.
There is more tension on the belt which made getting it on a bit tougher. A first test showed the belt rode off the motor pulley, and was over the flange at the bottom of the pulley. I think I can adjust the motor mounts to get it to ride on the pulley in the middle. But I am scared it may be too tight and could wear the bearing. Is my old one just stretched or is the new one too tight? Since I can't get parts for this thing, I surely don't want to mess it up.
John
John
