RyanJHippy
Hey all,
I recently started re-capping my Harmon Kardon 330c after seeing a swelled cap on the power supply board that made me nervous, figured I'd just knock it all out. I've been following @dlucy thread on his recapping experience with this unit, and so far I've been able to get most of the components on his recap+upgrade list, but not all.
I've taken the approach of doing one board then testing to make sure it still works properly to hopefully aid troubleshooting should something go wrong. After doing the main amp board, I went and tested and the bias pots could only push the current on the two resistors to 4mV, as opposed to the 10mV +/-1mV spec. I did the power supply board first, replacing the following:
C3,C4 with UVR1H682MRD (dlucy's recommended was UKW1H682MRD, but it was unavailable)
C7,C8,C13 with UKA1V102MHD (rec was UPW1V102MHD, but it was unavailable)
C12 with UPW1V220MDD
D1 with BR62
D4,D5,D601,D602 with UF4003-E3
D6 with 1N5243BTR
Q1 with BD1396STU
The bias didn't change after these replacements on the power supply and I was able to get a solid 10mV.
Then I did the phono board, though I can't imagine that'd effect the bias, I don't ever use Phono.
C101,C102,C119,C120 with UKL1V220MEDANA
C113,C114 with MKS2C041001FKI00
Q101,Q102 with KSC1845FTA
Then I did the main amp board, which is where the problem lies presumably.
C405,C406 with UKL1V220MEDANA
R433,R434 with CPF222R000FKE14 (Rec was CPF2-F-22 but it was seemingly discontinued)
VR401,VR402 with 3329S-1-202LF
D407,D408 with UF4003-E3
Q421,Q422 with KSC1845FTA
I think it's worth noting that, in the @dlucy thread, he had to attach the wiper lead on the new 3-lead variable resistors to one of the legs, since the original parts only had 2 leads. I found that the 3rd hole is just soldered shut, so I stuck all 3 legs of the new VR through. This was after I initially did the solder-lead-to-outside-leg method, thinking it was the cause for the low idle current/lack of range.
I appreciate any help anyone is able to give!
D1 with BR62
D6 with 1N5243BTR
Q1 with BD1396STU
