HK710 Tuner - No stations. Where to start?
RS-MN
I have an extremely clean HK710 Tuner that was part of a stack which included a HK750 Receiver and HK701 Cassette Deck. The Receiver and Cassette work fine, but the Tuner has no stations.
Backlight to the display works. No signal strength lights when moving the dial, no sound from stations.
Doesn't matter what antenna is used, it's not getting any stations on AM or FM.
Where to start? :dunno: I don't see any obvious component failure. it all looks like new.
Typically I would look at your power supply voltages first. Will need a manual to locate test points and a multimeter.
What PunkerX said, but I'll add that the transistor mounted to the U-channel heat sink near to the largest capacitors is almost surely the pass transistor for a power supply of something like +13VDC. It is a likely suspect, as are the solder joints for it.
If I'm correct, that transistor would be expected to have a voltage closer to +20VDC on its collector (center terminal), and around +13VDC on both of its outer terminals.
But this won't do you much good unless there is access to the solder side of the board in this vicinity. If there is no such access, a repair project might not be worth the effort. But of course that depends on how enthusiastic you are about keeping the stack together.
Black lead grounded to Chassis. Red lead on component:
The transistor has 0/-.5/-.5 (outer/center/outer).
I got the board out to a point where I can stand it vertical and solder on it. I've reflowed the solder joints of that transistor and items around it. - No change.
Voltages around the Transistor
D1: 13.4/-.1
D3: 27.1/-.45
Q1 - 27.0/0/0
Q3 - -14.7/-25.7/-15.3
Pin for green wires to display: 13.7V
Pin for Red wires to display: 13.7V
I've ordered some of the larger capacitors and will replace the ones around the Transistor. Maybe the transistor or a cap is bad?
Q1 - 27.0/0/0
Just as a point of etiquette, you might want to provide a pointer to the manual you are using.
Assuming I'm looking at the same manual, I think the above is the most relevant data, and I think it indicates that either Q1 has failed open, or D4 or C8 has failed shorted.
You could try temporarily jumping a resistor in the vicinity of 1200 ohms across Q1. If the voltage readings that were zero are still zero with this jumper in place, then I think D4 or C8 has failed shorted. My money would be on D4.
I downloaded the HK710 Service Manual here: HK710 Tuner Service Manual. HiFi Engine has the same one. I'm not aware of a better one. If there is, please post it or leave a link.
I'll find a resistor and try what you suggested.
Are there any replacements recommended for:
D4 - Zener Diode, RD15EB 14.7V +/- 0.9V
The closest I'm finding are these from internet searches:
"The NEC RD15EB is a 15 V, 500 mW, DO‑35 Zener diode, so the closest direct replacements are standard 15 V / 0.5 W DO‑35 Zeners such as 1N5245B or BZX55C15, provided their tolerance matches the “EB” grade." "If your circuit requires tight tolerance, choose BZX55B15 (2%) or 1N5245C (2%)."
BZX55B15 R0G is available at Mouser
Q1 -F.E.T. 2SK163 (M)
Note on Digikey: "Part number 2SK163 is not currently available but based on what I could find R6004JNXC7G-ND should be a match to the original part number." (R6004JNXC7G on Digikey and Mouser).
NEC Datasheet: 2SK163 Datasheet
C8 - 470uf, 16V - I have this.
Thank you for all the help! I don't do this much (which may be obvious...LOL!) and keep learning a great deal from the experts on this forum every time I get a project. Since I have the matching receiver and cassette deck, I'd really like to get this tuner going again.
For D4, use the component selector at DigiKey or whatever is your favorite legit parts house, to find a Zener diode with a Zener voltage of close to 15V, a power rating of 1/2 watt, and through-hole (axial) leads.
For Q1, I definitely don't like DigiKey's suggestion - not even close - but you could search for a JFET (junction field-effect transistor) with a specification called "Idss" of close to 10mA and a through-hole-leaded package that you can work with (might not be the same as original). Or, what I would do, and simpler to specify, is replace it with a current regulating diode with a current rating close to 10mA, power rating at least 1/4 watt, and through-hole (axial) leads. In DigiKey stock, it looks like Semitec E-822 would do nicely. The idea is that a CRD is a functional equivalent to what the original JFET was doing in this circuit. (CRDs were not readily available when this circuit was designed.)
For D4, use the component selector at DigiKey or whatever is your favorite legit parts house, ....
I find myself using Mouser more than Digikey lately because of in-stock issues, but I like using Digikey when I can as they are close and parts arrive faster.
I removed C8 and it tested at 475. I replaced it with a new one that measured at 468.
I'll get the other parts on order and update when they are installed.
Update - C8 and D4 have been replaced with new components. Still not working. Waiting for Semitec E-822 to arrive. should be here early next week.
Q1 reading 27.8/-.113/-.113
Swapped out D4 and D5 diodes, Q1 and CAP's in the power supply area. Some improvement in the voltages, but still reading low.
In looking at R1 and R2, I removed both. R1 measured O.L and R2 measured 11ohm.
Manual shows that they should be 10ohm, 2%, 1/4w fuse resistors. Having a hard time finding those with the 'fuse' feature. Suggested replacement? Maybe this: FKN50SJR-52-10R resistor
Also, the banding on the resistor suggests a 920ohm rating. I'm not sure if I'm reading that correctly or why that doesn't match the measured ohm.
Read the bands in the opposite direction. The red band is the 2% tolerance. Not sure about the white band.
I would just replace those resistors with any old flameproof 1/4W parts. I would not use the parts in the DigiKey pointer, which are 1/2W, so they might not sacrifice themselves soon enough in a fault condition.
I put in a couple of generic 10ohm, 1/4w resistors. 5% tolerance. But it is now working and sounds great! I should find some flameproof resistors with a 1%-2% tolerance and install them before I get it all back together. Fusible resistors are near impossible hard to find. I see a couple metal film with flame resistant coatings in stock at Digikey that would work.
CMF5010R000FHEB - Vishay - 10 Ohms ±1% 0.25W, 1/4W Flame Retardant Coating, Moisture Resistant, Safety Metal Film - up to 175°C
RN60D10R0FRE6 - Vishay - 10 Ohms ±1% 0.25W, 1/4W Flame Retardant Coating, Military, Moisture Resistant, Safety Metal Film - up to 175°C
Don't think I need Military. I'll get the other one.
It's a really cool tuner. The display backlight is white until it is tuned to a station, then it turns light green. All the LED's for signal strength/stereo work.
Thanks for your help everyone!
