Thanks. In person it looks a bit better than the photos. Sort of like distressed leather, or that it already has a patina on it from age.
As to the basement, both windows sit a couple inches above ground level, the larger facing the front yard. Opposite the large window is completely below grade. The garage is off to the right and is on the grade.
Oh, I forgot to add, to deal with the pretty obvious light/dark wood wavy pattern, since I had already stained the one wall, I added a second coat of stain to the light portions to darken them a bit. For the two other walls I hadn't stained yet, I did a second coat of the shellac sealer on the dark wood prior to doing the base stain coat. It really evened out the grain pattern which I hadn't considered when I bought the lauan to begin with. Glad I was able to recover from it.
