AnzacSonata
I've been through the mud and back with this one...and it seems no matter what I use, it just PUTS scratches into the discs...
With vinyl, my cleaning routine is simple and effective (regardless of what's been said about it): Use a drop of Dawn dish soap, mix into a tiny bowl of warm water, apply with soft, clean sponge in the direction of the grooves, rinse, et al...
It seems with the more DURABLE medium -- the Compact Disc -- my results are all over the place, as are the online suggestions for cleaning them. I've tried the toothpaste method, applying car scratch removal ointment (Meguiar's "Scratch-X" to be particular), soap and water, just water, glass cleaner, eyeglass cleaner...
I have found that -- even when applying these chemicals the proper way with CDs, which is to apply and wipe from the inner ring OUTWARD, the opposite of a vinyl LP's routine -- after taking these cleaned discs out of my Marantz changer once they've been played awhile, there are streaks, marks and sometimes even scratches on the playback surfaces that didn't exist before I played them.
This just happened with a Linkin Park CD I cleaned, Meteora -- there didn't seem to be any scratches on the disc when I cleaned it using the dish soap-and-water method, but when I dried it off, there seemed to be tiny microscopic etchings that came to life under the light...
Is this because of my drying method? The chemicals I'm using? Honestly, what's the best way to clean CDs, even if they don't necessarily have scratches?
