hook up help
troutfisher
Well-Known Member
I'm trying to hook up a rt 707 and a ct f1250 to a Sansui 8080db this is what I find.
When I hook up the 1250 as tape deck 1 with a pioneer sg 9500 and the rtr as # 2 using a 5 pin cable the rtr does not play though the EQ.
If I use the rca cables and go to the 1250 then it plays though the EQ
does this sound like the right way to hook it up?
if so can I use # 2 tape deck on the Sansui with a 3rd tape deck with the 5 pin cable?
Thanks dazed and confused
I also use 2 tape decks, CT-F950 and RT-909. If you hook them up like you described, skip the 5 pin. (Why a 3rd tape deck?)
Both those decks have source,tape. I keep both in the source position, monitor Tape 1. If you want the tape 2 to go through the EQ, use the Dub, 2>1 position. There ya have it. For Tape 1 switch the dub to 1>2.
Oh, and never....NEVER have both dub switched on at the same time when both tape decks are in the source monitor mode. You WILL blow tweeters that way. Believe me....I know.
There are L +R Mains Pre and Outs on this Sansui so you can hook your Eq there,I know many don't believe you should do this but hey it works!I have a Pioneer BOTL SA-7800 Amplifier and run all these CT-F 500,Marantz SD-3000,Pioneer CT-W900 R and RT-707. My RG-1 Processor runs out of EQ and the SD-3000 in tape 1,CT-F500 with the CT-W900R in tape 2 with RCA Y Cord Splitters and R to R out of RG-I and they all work fine for me and have for quite a while...:)Everything including Tuner runs through the EQ and RG-1 Processor as needed or not!One thing though you can only use one or the other but not both when you have 2 Decks running with the RCA Y Cord Splitters running on either Tape 1 or Tape 2 whichever Tape you use for 2 Decks!!!Been told this would not work but I'm telling you it does.......:)
