You are wrong. Search "Lexicon" under Zilch.If I'm wrong, say so. If you know better, explain it better than I did.
just make sure you use a sub like Epos or JL as there is a massive differance between a sub made for 2 channel and a movie sub.
clmrt,
did i miss something? :scratch2:
When I y's the pre signal I went to the sub amp and out to the sub. With other end of the y, I went to the Denon's amp section. Then I sent the Denon's speaker out into the speaker switcher so I could switch between the Mission 770's and the Klipsch KG 3.2's.
Do you think it could make a difference? I would think that the sub is still getting the same signal, especially when I turn off the speakers. It is as if the sub amp is just a passive crossover. The louder I run the pre, the louder it gets. But if I feed it a low volume signal, it won't raise the volume of the signal any significant amount.
I'll try it though, as I would love for this thing to work.
huh?:scratch2:
Most subs are made to spike at 50hz to 60hz as much as 20db then drop like a rock from a plane at 30 to 20HZ.Movie subs are ported and often have a longer excursion.Makeing them slow and rumbleing not fast and accurate. A sealed 10 inch car sub will out preform most surround sound subs.One of the better of these movie subs was a horn loaded Yamaha with 2X8inch fast fireing subwoofers it had a switchable Xover for 2 channel but could not go much past 28hz. and was -6db at 30hz.
thanks markw.
i've heard a few set up with subs and i thought it was a totally different experience.
so, what's the rule of thumb when setting the sub xo point?
