I have a normally functioning G9700 and trying to set the bias. The manual says 5mv, but I am getting 246mv both left and right with the vr all the way counterclockwise. Everything acts normal, the mv climbs and stabilizes, the voltage responds directly to the vr. I have tested the fuse resistors and they are showing 1.43 k ohms in circuit - I believe the manual says 3.3 k ohms.
Before I start pulling parts, etc. wanted to check here for thoughts. The unit doesn’t heat up or draw excessive current. This is what I am working with
