how connect TSR-7850 to ROKU Smart TV?
Reading the manual, even a quick start version, would give you the information.
But, no, not just any HDMI port. The ARC port on the TV has to be connected to the display/monitor port on the receiver. Sometimes there are two display/monitor ports on a receiver. Use the primary/#1 port if it's the only TV being connected.
But, there are other settings in the receiver you might need to check to enable ARC function. The manual is your friend. ;)
My receiver does not have a display/monitor port - Are you referring to hdmi input 1 Movie? or HDMI Out 1 ARCX
BTW, I never did this before, so please be patient.
I read again more carefully, thank for the info.
Connect a TV to the unit with an HDMI cable. If you connect a TV that supports ARC to the unit, you can output video/audio to the TV or input TV audio to the unit
