Vint_age
For the best finish using Watco;
If you are not applying to new/raw wood, make sure previous finish is oil compatible. Do not apply over lacquer, varnish, poly or Howards.
Wipe surface with Naptha and a 3M pad to remove any wax or oil build up.
Sand surface by hand with 220 paper on a block. Vacuum/blow dust off.
Wipe again with Naptha on a rag.
Apply Watco with 400 grit paper on a small (2x3) block. Use just enough oil to allow the block to slide without sticking. Work the oil until a light slurry covers the entire surface. Wipe off and move on to the next surface. You should be able to do an entire speaker cabinet with a teaspoon of oil. There is no advantage to saturating the veneer with oil. The slurry will fill the open pores and give porous wood like walnut, ash and oak a very smooth surface.
Let dry for 24-48 hours. If you like how if looks and feels you are done. If you want a little more sheen/build, apply another very light coat with 400 paper again.
Repeat every couple of years if necessary, just wipe with Naptha / 3M pad and apply the Watco as above. No need to put any wax, oil or polish on the Watco, all it will do is attract dust.
