ripblade
Addicted Member
You can discharge static by touching your dog's nose. But probably only once.
Get yourself some ESD (Electro Static Discharge) footwear. Plenty out there available. Just might do the trick for you.
No Ken, not just in the chair, it's everywhere like getting out of my truck and getting zapped when closing the door, touching a door knob ect. Some days are worse than others, I live in a very dry climate so I guess that doesn't help much.I think his problem is when he is sitting in his chair, not when he is walking.
Yeah they don't like that. Not one little bit. As my cassette deck is the right height and right below my main turntable I have a metal adapter plugged into the 1/4" headphone jack. This tt is manual so I touch the adapter before I lift the arm. It does cause a loud pop from my speakers though.
I think folks thought you were asking for advice. I like your solution. Is it the sorbothane or because it's touching the conduit? I have a partial metal equipment rack that does the trick but it still makes me nervous for my equipment.I've taken an old Sorbothane mat and stuck it on the wall behind a conduit.
I need to touch something else before the turntable because the fine folks at Technics made my whole turntable out of metal including the off switch. The Sorbothane mat is stuck to a brick wall, so the static goes nowhere else. I've actually temporarily shorted my tube amps touching my turntable with a charge. Once I've discharged myself (sounds kinda rude, I know) there's still residual static on the record when I lift it off, but it doesn't affect my system. I will investigate getting a Zerostat gun. I bought the newest Audioquest carbon fibre brush with the gold sides, but I'm not sure it's really an improvement over the old one. Interestingly, even though Portland is known for being rainy, it's residual humidity is quite low. It's a rainy day and the humidity is only 75%.
The Sorbotahne takes the first hit and because it’s against the brick, the shocks go nowhere. Also, it’s an easy target to remember. It does zap, but it can’t hit my gear. The conduit happens to be behind my turntable and it was easier to wedge the disc behind it against the wall than driving a hook into brick. The conduit makes it look “tech”, though.I think folks thought you were asking for advice. I like your solution. Is it the sorbothane or because it's touching the conduit? I have a partial metal equipment rack that does the trick but it still makes me nervous for my equipment.
Wow that Aerostat looks the business! I love stuff like that. I’ll check them out since they’re near by.Your static issue does surprise me as I lived in Portland for almost 20 years and spend a lot of time there still and never had a static problem. But now I live in what is seemingly the driest most static prone place on earth (not really). A few years ago I fried a bookshelf system with one shock from my finger. No big loss but hurt like hell. Then a couple years ago I thought I fried some expensive tweeters from the same thing but I got lucky. Thank god for fuse protection!!!
I recently ordered a hygrometer and a humidifier from Amazon but the shipment has been delayed because it isn't essential or whatever. I get it. Weird times.
For static on records I went a different way. I had a zerostat but it didn't always work and eventually broke (bought used on ebay) so I went industrial. I bought an industrial aerostat ionizing air blower. They're used in the manufacture and assembly of circuit boards etc. I got it used cheap from Hillsboro, OR actually. Shipping was more than the unit. It works very very well. Only on for a few seconds when in use. Pass both sides of the record under the blower for a few seconds and static is gone.
Now I have a project, run a wire to my outlet ground and find something to make a touch pad. Maybe a 1K resister in line.Not good! Could easily damage your components or speakers. Ask me how I know![]()
1 MEGΩ is a typical value to go between a hard ground and a static discharge point like a mat or wristband, and reduces the current flow to a safe level.Now I have a project, run a wire to my outlet ground and find something to make a touch pad. Maybe a 1K resister in line.
