flavio81
Turntable technician
Hi,
This is useful information for troubleshooting the Sony motors: Understanding how they work.
First, it's important to say that the info here is NOT useful for the first-generation (1971) DD motors as found on the PS-2251 turntable. These motors work under a different principle.
It is also NOT good for the second-generation (-1976) Sony DD motors which say use the "saturable inductor". These are different motors.
The info is good for the third-generation Sony DD motors. These are readily recognizable by the two sets of coils in butterfly shape (see below) and the use of hall sensors. Also, all of them use the magnetic imprint on the platter for reading the actual platter speed (note that 2nd generation also use the magnetic readout too). A nice and interesting thing is that many Technics DD motors and some Hitachi motors use more or less the same system.
Pictured: Sony PS-T1 motor sans rotor nor spindle. Look at the sexy coils.
Examples of Sony DD turntables that use this third-generation system are: Sony PS-X50, PS-X70, really all Sony Ps-X series, PS-242, PS-11, PS-LX3 and others, even the tiny PS-Q7 uses the exact system. And others.
Sony PS-LX3 motor:
Now, how does this work? The Sony PS-11 manual has a great explanation. Please read carefully:
So, the rotor has many magnetic poles, as you can see, and there are two Hall sensors, H1 and H2.
The Hall Sensors are the little black (or blue) things next to the coils, and have 4 terminals: Two terminals receive a bias or control voltage, and the other terminals deliver a voltage that is proportional to the magnetic field. If the rotor spins, the magnetic field varies, and the output voltage will then be a waveform. If the control voltage is higher or lower, the output voltage amplitude will vary as well.
Let's continue with the text:
So, to make things simpler:
The two sets of coils require to receive sine waveforms with the correct phase relationship to make the motor rotate. The generation of these sine waveforms is made with the help of the hall sensors themselves, because when the poles of the rotor go through the hall sensor, the hall sensor generates a signal which is then amplified (Q10, Q11, IC1-4, etc) and fed to the coils. And this is how the rotor spins.
So the rotor spinning is what makes H1 and H2 (hall elements) produce sine waves at the out, and those sine waves, amplified, are delivered at the coils to make the rotor spin... It's a match made in heaven.
So how do we vary the speed? What makes it go faster or slower?
The PS-Q7 manual has a simple enough block diagram that will help us:
At the right we see L1 and L2, the motor coils. (On the picture they look like four coils but electrically they're two.)
How we see our friends H1 and H2, the hall sensors. And something called "DC Amp".
This "DC Amp" will give a control voltage that will decide the speed of the turntable. This voltage is what provides what I call a "control" voltage to each Hall element. "Gain" allows to do an adjust of this voltage, probably to compensate for Hall sensor differences or coil differences. The service manuals all explain how to set gain but it's obvious that we want the output from the hall sensors to have pretty similar waveform amplitude and we can use "Gain" to achieve that.
We can also assume that too much gain could fry the hall sensors...
Now, the output from the hall sensors go through an amplifier made with an opamp and two transistors, and this amplifier directly drive the coil. What's the "offset" control?
Again, getting back to the PS-Q7:
We can see that the "Offset" control will allow us to tweak until we get a symetricall waveform to the coils.
PS-X50 manual:
What is the manual asking us to do? What's "disconnect the white wire and connect the regulated power supply"? In essence, what we're doing is disconnecting the control voltage from the DC amp (see prior diagram) so we can supply our own, fixed, control voltage.
Then we need to check that the output waveform, the one that would go to the coils, is symmetrical. This can be done with an oscilloscope (you really need an oscilloscope if you want to troubleshoot most DD turntables), or by assembling the circuit on the picture and checking that the out is 0 AC volts with a VTVM or digital multimeter sensitive enough. What this circuit does is rectify the positive side and the negative side, smooth it, and substract one with the other; ideally the out should be 0 volts.
So that would be the offset adjustment and the gain adjustment.
Now, what's the magnetic imprint on the platter for? And the magnetic readout head? Those are for controlling the speed circuitry that ultimately produce the control voltage that appears after the "DC amp". And the control method would differ if the turntable is quartz-locked or not. Most QL turntables use the CX-193 Sony IC for the control. But all of them have the magnetic head.
This head reads the magnetic imprint on the platter rim and should produce a periodic output waveform. For example on the PS-X50 and similar TTs this would be a waveform of 284Hz (see image) and a magnetic head output voltage of 30mV or more.
Now, how can we troubleshoot? How do we proceed? I will explore on the next post.
Sony PS-LX3 motor:
PS-X50 manual:
