You want to place the treatments for the side walls at the first and second reflection points.
When you get it right you should be able to tell immediately an improvement.. The WAF comes into play! Good luck!
Did you build a ceiling? If so, at what height? Assuming that the base floor is concrete, what type of floor covering are you using?I built my own room in the barn
Yep, ceiling is 7'. The floor is wood with a 9X7' rug between the speakers an listening position. Speaker stands are spiked.Did you build a ceiling? If so, at what height? Assuming that the base floor is concrete, what type of floor covering are you using?
I'd think that a larger rug or carpet in your listening space would make as much difference as wall coverings. It all really depends on what type of sound you prefer. Every change to your space, whether it be wall coverings, floor coverings or even repositioned furniture will affect the sound that you hear. Just like with everything else in the audio hobby, experimentation is key.Yep, ceiling is 7'. The floor is wood with a 9X7' rug between the speakers an listening position. Speaker stands are spiked.
Just 1/2"sheet rock. Took me about a month to build out when I retired. It's my man cave in the barn.Wow! Impressive. What is the ceiling material? I would think it could also be absorbing a lot of standing waves.
Several years ago I helped a sound engineer friend build sound panels, using recycled denim, for a recording studio he was putting together. Some were put on the walls, and some were hung from the ceiling.I looked up the acoustic properties of r-5 pink foam. That ever present online pest AI said it doesn't adsorb sound waves but rather can reflect them. If we can believe AI, using it may be part of the problem. My experience with materials with sound adsorption properties when I was building speaker enclosures many decades ago was that wool or jute padding was superior to fiberglass insulation or foam padding..
I have more examples in mind that work, density is the key it seems.Several years ago I helped a sound engineer friend build sound panels, using recycled denim, for a recording studio he was putting together. Some were put on the walls, and some were hung from the ceiling.
Recycled denim is very dense, and used to be (20+ years ago) relatively inexpensive, and readily available. Not so anymore, for either. Because of that, I'll be using Rockwool Safe N sound when I I make my panels.I have more examples in mind that work, density is the key it seems.
I've installed some very non scientific room treatment. Yes, I do hear a difference, better?How long to determine if it is really better, or not? I know every change we make can make a difference and it takes awhile for our ears/brain to adjust, but...
