Pioneer.user
This thread Will be educational. It was inspired by one dudes experience. He saw once Elite separates components for sale for small amount of money, but he didnt buy it cause his brain was programmed to label everything black as black plastic crap.
So we Will answear this question, is Elite components (True Elite components not audio video receivers vsx) bpc?
First of all. Pioneer c90/c90a/c91, m90/m90a /m91 front panels are not plastic but made of aluminium.
Next, how about build quality? How about components used to build Elite Gear?
- output transistors are toshibas a1516, the same transistors are used in few accuphase amps including 12.500 usd high end accuphase p800.
-u con capacitors are the same used i many other high quality amps like 12.000 usd luxman m06/c06 combo, tubę amp luxman cl360/mq360, 9000 usd denon das1 dac etc
-soshin mika capacitors, the same are used in pioneer exclusive c7 and other
- polypropylene film caps, the same are used for example in 9000 usd denon das1 dac, sansui alpha, sansui b2201, 907i
-nichicon mylar film caps, used also in pioneer exclusive c7 preamp, luxman amps
-wiring used in building Elite components are pure Ofc wires, internal wiring and power cables, Just like in pioneer exclusive gear
-chassis are copper plated
Pioneer c90/c90a/c91 phono stage has exceptional build quality. Phono is built on 2 step up transformer which was unusuall even in 80. It is True non compromise phono stage build quality, seen nowadays in high end phono stages.
Conclusion
Is Elite bpc? Not even close. Build wise its high quality Gear that can rival spec (which is not better built) and its better sound wise and build wise than any pioneer receiver. So not everything thats black is crap. Time to remember that.
Below for reference, True black plastic crap with plastic front and defiled Elite tag. Sc lx 901
Conclusion
