How much is an Empire 598 ii troubadour worth?
vaathi
baski
Working but need some TLC state and seller is asking 450 cash after negotiations. Is it worth that much..It has shure V15 type 2 cart in it.
TIA
In good refurbished and complete condition it probably is worth that much.
If it's the one out in your area that I found. I'll bet you a dime against a doughnut it will not be there in a couple of weeks.
If the table is in sound condition I personally would not have a problem with $450.00. But that's just my opinion after seeing the table you are talking about.
But there is not a damn thing wrong with haggling either.
It's hard to be 100% sure from the pictures, but that tonearm looks to be free of corrosion. I recently lucked into a 598 III so I've been reading quite a bit about them and most of the pictures I've seen the deck and tonearm are not as clean as the one you're looking at. Taken as a whole it's not exactly pristine, but it's probably right in there with the going rate for one that should clean up nicely.
