Ben Rothman
Hello everyone, I have a Nikko NR 1000 reciever and I'm wondering how manys watts per channel it gives out with 4 ohm speakers. With 8ohm speakers it has 60 WPC. On the back of the reciever underneath the speaker terminals it says "A or B 4 ohms to 16 ohms" it also says " A + B 8 ohms to 16 ohms" I know that means when using either speaker A or B I can run speakers from 4 ohms to 16 ohms, and when using two sets of speakers at the same time I can only use speakers from 8 to 16 ohms. If anyone has any information on how many WPC the NR-1000 has when using 4 ohm speakers that would be great.
Thank You!
Thank You!
