z-adamson
Addicted Member
Now that's extreem! My gear does not even hold a candle to what you have going on.SPL= Sound Pressure Levels
From what I read form your post you don't have a problem, just because you feel vibration on things in the room doesn't hurt anything. Now if your turntable phono cartridge is picking up the SPL it will loop into the system and you will be forced to turn it down. I can turn my system up so loud without any subs and have it knock things over across the room and be using the turntable to play the music doing it, that's isolation.
I made these clips all in one day stretching out the systems 2000 watts
In this vid I stopped it because I felt / heard something fall over.
Here I re-started the recording showing the **** that fell to the floor.
Anyhow, do you isolate your amps, preamps etc? Or just your turntable ?
