How to clean a tuner (analog)
CorrosionX is not a cleaner. It's a lubricant that has anti corrosion properties and enhances conductivity. It's certified safe for electronics so you can use it in modern potentiometers. I've been using the "regular" version. I first found it a local boating store in a spray can but have since bought it on line in pump spray bottle. I transfer it from there into a needle bottle applicator. That allows you to dole it out one drop at a time.
You need multiple DeOxit products to do what CorrosionX does. D5 is a cleaner/conductivity enhancer but it doesn't lubricate. Faderlube (or whatever the hell they call it now) is a lubricant that neither cleans or enhances conductivity. D100 is just a conductivity enhancer.
I have not been doing much bench work over the past couple of years so I really don't have that much experience with it but it worked like a champ on this tuner.
- Pete
- Pete
@LBPete thanks for the comments. I did realize it is a lube, not a cleaner. I'm glad you mentioned getting it at a boating store. My son and I use products and tools from one hobby in others. We have some boating projects planned for next Spring. I'm thinking of trying the HD or XD on that stuff.
Please forgive the redundant question, but I've now read through this entire thread from 2008 to present, and I'm still unsure about what to buy to do this work.
I have a Sansui TU-217 and a Tivoli table radio that I'd like to clean. I'm tentatively thinking of getting one of the following for cleaning : (1) MaxPro Contact Cleaner, (2) WD-40 Specialist Contact Cleaner, or (3) CRC 05103 QD Electronic Cleaner, all of which are non-residue. And a tube of liquid DeOxit FaderLube to apply afterward. Are these all okay? I have some DeOxit D5 but that is NOT okay as it is not non-residual, correct? Many thanks for clarifications.
Don't use MaxPro Contact Cleaner, it has lemon flavor extract in it. WD-40 Specialist Contact Cleaner should be fine, followed by the Fader Lube.
I use CRC QD Electronics Cleaner on tuning capacitors, and lube with a tiny bit of Caig L260NP. Faderlube or any gun/sewing machine oil is probably also perfectly fine.
Thank you, and much appreciation for your maintaining this thread for what's now almost twenty years!
