QSilver
If your doing the rest of it, you probably should. But you might struggle to find ones that have the original dimensions. They'll work just fine, but you might need to pad out the original capacitor clamps or get new ones.
They are the AC filter capacitors for the main power supply for the amplifier so they are quite important. There are four because the Mk2 is a dual power supply model. Two per power supply (positive and negative) if that makes sense...
Hope that makes sense!
