mhardy6647
Lunatic Member
... and a broken watch, unlike the Rolex or the Timex, is exactly correct, twice a day.
I'm told Timex watches perform as well as Rolex watches. And the drivers and boxes, properly used, are capable of excellent performence.
Just looking at the back of the speaker... It could be an easy try.
He's got a tweeter control level at the back which can be removed. In that hole you could try some resistive material like fibreglass or Dacron or something.
This way nothing gets destroyed trying it out either.
Just a thought?
Just a thought?
I tried pulling that assembly out but it is glued in as well as screwed in. Same with the binding post plate. That is why I'll have to use the tweeter opening for the port to experiment and get it right before I drill a hole for the permenent port.
I just tried Faz. That plate is just a plate, not covering an opening, just the hole the stem fits through. I think for just tuning the woof, making an adjustable length port for the tweet opening will work well. As for port placement, I will do as you suggest and keep the port away from the woofer but it has to go in back. Putting it in front will mess up the design.
