How to ground turntable with amp that has no phono ground screw?
can-man
Can I use just any screw from the back of the chassis....it only hums when turntable is on.....Dual 1226 with Shure V15 V.
In many (not all) amps the case is earthed to prevent loose power wires causing the case to become active and endangering users, so using one of the screws on the case will earth the turntable’s tonearm (and other metal parts if they are also connected to the turntable earth wire). Good to see you managed to cure it - you've got a good cartridge (if you can believe me - I've got one too!:D), so you don't want it humming.
Don (hi, btw! :)): "Many" might not quite be the right word, though - 'cause in my view the vast majority rather are safety class 2 (i.e. "double insulated"; case usually tied to "signal" ground...) than class 1.
Greetings from Munich!
Manfred / lini
Hi Manfred. Yes, I deliberately didn't include any mention of double insulated amps, but certainly there are a lot of them. Perhaps "some" would have been more accurate than many!:thmbsp:
