How to hook up KP-301 II ? No manual available
CavScout
I am trying to hook up a set of KP-301 II speakers but I am used to just hooking to a red and black connection on the back.
These have :
2 reds
2 black
2 fuses
2 plug inlets (banana)
Not sure how to hook up.
Do I have to use banana plugs ?
Or do I just bridge join each red and black to their twin and then just hook to either one of them?
The klipsch site does not have a manual so any help would be greatly appreciated
Thank you
Bottom binding posts probably are connected to the woofer and top posts to the midrange and tweeter.
Bi-wire or use jumpers.
The other connections look like 1/4".
Use any of the connections. Happy listening!
Cant just use any of the connections, they are high & low specific. As opnly mentioned they need a pair of jumper wires or straps or use real biamp connection from 2 amps. the other 1/4" connections are more intended for pro audio hook up, can leave them alone.
All depends on if the oem jumpers are intact.
They're located on the inside of the cabinet.
If they are removed then external jumpers would be needed when using a single amp.
