So long as the flanges are recessed into the baffle such as to be flush with the surface, it will be different, but not inherently bad. You're already doing "different" by unclustering the drivers.
Your major problem with that design is that you have the top three drivers on the centerline. Offset them to one side and the other by a couple of inches and put both ports on the other side.
Why? Because you have equal distances to the cabinet edges, which will reinforce deliterious edge diffraction effects for each of those drivers. You want them to occur at different frequencies so that they will not sum....
