Racingh11
I recently modified an MCS 3245 receiver to greater power output using a 3275 transformer and other modifications. It can be read in this thread: https://audiokarma.org/forums/index.php?threads/how-to-increase-power-mcs-3245-to-3275.968122/
The second conversion I did in that thread left me with a good 3245-10 transformer. So now, I'm installing that in an MCS 3235 receiver and making necessary changes.
This build will require all new power-amp transistors, due to voltage requirements. The transformer is the same physical size as well as the rectifier diodes. Should make it easy. Fuse amperage will be increased. And a temperature controlled cooling fan will also be installed.
It is also getting a complete electrolytic capacitor replacement and larger power caps.
Pictures and details coming soon.
