How To Load A Tape Pancake On To A Reel
Des_Lab
Banned
In light of the recent discussions regarding tape and tape 'pancakes' coupled with the realization that many of our fellow tapeheads here have no experience using pancakes (known as 'traypacks' in the official jargon), I feel it my duty to explain, step by step...complete with pictures on how to perform this procedure.
It is not difficult nor time consuming. Although first timers may feel a little apprehension, I'm here to tell you to relax. If you follow my instructions, you will find it quite fast and easy to do. The whole process can be done in five minutes or less. Ready? Here we go.
First is shown a pancake of tape. For this demonstration, I used a Quantegy #457 3600' quarter inch 'cake. Also shown is an empty metal reel. It is not quite matching (it is stamped for a #407 tape), but it *IS* the reel I use for these projects and for this tutorial (and for that matter, all transfers), it will suffice just fine. The only tools you will need will be two screwdrivers. One is a standard size Phillips head. The other is a small flathead. Although a standard size flathead could work, the small size and lack of a real workable area means that the smaller head will grip the screws and hold better.
The first step will be to separate the flanges from the reel. There are three screws holding the flanges to a single hub. If you are using an un-tampered reel (or one that has been properly assembled), the Phillips screws should all be on one side and the flat heads on the opposite side. Begin by using the Phillips to loosen those screws. Once they are loose, using your other hand, seat the flathead screwdriver on the other side and HOLD it while removing the Phillips head. They should remove fairly easily. Should you try and remove the screws using only one screwdriver, you will find yourself spinning...and spinning...and spinning...as the two screws spin but not unscrew, as the flathead is not a screw per se, but rather, a socket that the Phillipps head bolts down into. This is why you need the two screwdrivers.
Once you have all three screws and sockets out, remove the top flange and set it along with the hub aside. At this point you can dispose of, or place the hub in a safe place. It will not be needed for re-assembly.
Now comes the critical part. This is the single most important step...this is where you actually put the pancake onto the reel.
On as level of a surface as you can muster, lift the pancake with one hand and slide it out of the bag and grasping it with your other hand. Whatever you do, DO NOT REMOVE THE HOLD DOWN TAG THAT IS HOLDING THE END OF THE TAPE TO THE PANCAKE!!! Doing so WILL result in tape getting spilled all over the floor and result in the ruination of the pancake.
The best way to handle one is exactly as you would a vinyl record: by the center and edges. Do not worry about "spilling" it. The tape pack is wound very tight. As long as you don't drop it on the floor or grip it so tight that your thumb slides off the tape pack dislodging it, you will be fine. Hold it with just enough grip to keep it from dropping. You don't need to apply a "vice of death" grip. I should also mention: don't touch any more of the tape than you absolutely have to. If you grip it right, your thumb will be making contact with nothing more than the very top layer of tape. Although as with cooking, it's best to wash your hands with soap and dry thoroughly before performing this procedure.
Next is to actually set the tape onto the flange. It's absolutely crucial that you line it up properly, or else you won't be able to re-assemble the reel. The "new" hub (which is what the tape is loaded on and why you no longer need the one that was in the reel before) will have a total of six cutouts: Three for the reel tables (seen as sort of upside down "U" shaped in the outer diameter of the hub ring) and three screw holes in the surface of the hub itself. As gently as you can (don't drop it), set the pancake on the flange, making sure all of the cutouts are flush with each other.
I should also point out there is no wrong way to do this. The dimensions of "up", "down", "left", "right", "top" or "bottom" do not apply here. Once on the reel, the tape WILL work. If the tape ends up facing the "wrong" way" when you are done here, you can either load it on the deck and "rewind" it or else flip the reel 180 degrees and voíla! Ready to go.
At this point, the "hard" part is over. All you need to do is re-assemble the reel. Basically, it's simply performing the above disassembly in reverse order.
Begin by setting the other flange back over the tape and lining up all of the cutouts and screw holes. Then drop one of the Phillips screws back in one of the screw holes and locking it in on the other side with a flathead socket and screw back together for each of the three holes. Only this time, HOLD the Phillips head and turn with the flathead. Set the three screws first and then once they are on, go back and torque them down. Get them snug and tight. Enough to where they won't work their way loose. But not so tight that you strip...or worse...shear them off.
Congratulations! You have now successfully loaded a pancake and are ready to begin recording. NOW you can remove the hold down tag. At this point, you can either splice leaders on (strongly recommened) or else load the reel and tape directly onto your deck and begin using it. Either way, it would be good advice to trim and dispose of the first layer of tape as this is the surface that you handled and might be contaminated with thumb prints. It is recommended but not required to complete at least a one-way high speed (fast forward or fast rewind) of the tape prior to actual recording. This will loosen up the pack and even out any possible surface irregularities that could compromise your recording.
Hope this little post helps. Enjoy.
DL-But I had a burrito for breakfast
Thank you for taking the time and effort to post that, excellent info :thmbsp:
Now all I need is to find a decent RTR...
Great tutorial. Very useful information. I for sure now know that I have no interet in attempting this. I have always used tapes prewound on reels. My only remaining challenge is finding a source of tapes that I am comfortable dealing with, and a brand of tape I know or can become knowlegable about.
I haven't bought a new reel of tape for 30 years. I have been playing all the tapes that I have on hand, and still after all these years find them to be quite brilliant.
Good information, should be stickied.
I used one screwdriver and my thumb to remove and replace screws and i tried not to touch the tape at. I gripped mine from the hub only and set it on the flange in my hands not on a table.
I most whole heartedly concur-----This thread needs to be "stickied".
And, this RTR noob is greatfull for the instruction!!!
Thanks!
Dave
Next, show how to splice leader, and splice tape in general.
I used to be able to do all this stuff.
Fantastic post - many thanks from an aspiring tapehead. I know it's important to support new tape suppliers if they are to stay in business, so buying pancakes is a more affordable way to enter the new tape market. I am sick of listening to my 6 tapes over and over :boring: Now I can actually invest in some decent brand spanking new tape without having to shell out a small fortune. :thmbsp:
Great tutorial, DS, but instead of picking the pancake up and risking it coming apart, I would suggest you just set the reel flange down on top of the pancake, hold it in place and simply invert the whole thing, leaving the pancake now laying flat on top of the flange, ready for mounting.
That would work too. But it's a much more complex process and would've been much more difficult to to explain. I also feel that doing it your way *MIGHT* leave you more vulnerable to spill as doing it that way gives you less direct control of the pancake. I've never, not once spilled or damaged a pancake using the method shown in the original post.
But anyway, glad you guys all like it. Someday soon I'll post another tutorial. But this time, as suggested, how to do splices. Definitely don't want to use Scotch tape, duct tape, masking tape, or electric tape! Very bad. But I'll leave all of that for that post.
DL-Roll 'em
Please show how to splice with and without a block if you use one. If you are like me you dont have a block, and dont really want to shell out for one.
Yes please. I've always wanted to be able to do this. When you watch people edit this way, they just whip it out like it's nothing. Case in point: John Baker in the BBC documentary The Alchemists of Sound. The guy is casually smoking a cig, making edits and POOF! like magic he has a finished audio track.
I don't use those straight blocks and a razor blade. Those are pretty tricky. I've elected to go the 'wimp clause' route: I use those all-in-one units that have the clamps, the tape cradle, and the rocker arm that has the directional blades built into it. Works just as good as a straight block as far as I'm concerned. I already said I'll do a tutorial for that. But it definitely won't be today. Am getting ready for the Super Bowl and tomorrow is back to work. Maybe next saturday, I'll break out a tape and camera and do a couple of splices and explain it step by step for all of you.
DL-Choice cuts
