Sliglebone
Hello,
I'm trying to figure out if its possible to listen to air FM/AM radio stations with my Marantz 2285b, and have the digital reverb unit (a Pioneer SR-303 Reverberation Amplifier) process the signal. I've had success in having the reverb unit's lights and effects work when playing a CD player through it via the AUX port on the Marantz, however I can't seem to get it to work on FM/AM radio.
In order to try to push FM/AM radio through the reverb unit, I connected the Pre-Out from the Marantz to the Input on the reverb unit, and then connected the Main-In on the Marantz to the Output on the reverb unit. I then can play a radio station, however the reverb effects don't seem to work on the sound, and the reverb unit strobe/light display doesn't light up. However, I do notice when I flip the Reverb effect off and on (not the reverb unit's power button, but rather the on/off for the reverb effect), that the volume or gain seems to attenuate higher and lower by some DB amount. I think this is because of the setting of the Attenuator button on the back of the reverb unit. I've turned the Attenuator button on and off, and in either position there always seems to be a difference in gain/volume when I turn on/off the reverb effect button. An interesting side effect of running the radio through the digital reverb unit, is that some of the static in the station signal appears to have been cleaned up AND the range I can turn the tuner dial and hold a clear signal on one station seems to be greatly expanded (e.g. I can have the FM tuning sensor needle go way further left or right of center without the signal breaking up).
My question is, why does the reverb unit seem to only work with a CD player? Is it because the Pioneer SR-303 will only process a digital signal? From what I understand, it is meant to work when hooked up to TAPE as well. My general thinking with using the Main-In/Pre-Out connections on the Marantz was that ALL sound passing through the Marantz could get treated by the reverb unit.
Also, why does the reverb unit seem to create better range on the dial for receiving a cleaner signal?
Any thoughts?
Any thoughts?
