cerda_daniel
Hi everyone,
I have a vintage Pioneer setup, including the SPEC-1 preamp, SPEC-2 power amp, SG-9800 equalizer, CT-F1000 cassette deck, and RT-707 reel-to-reel.
I've noticed static on the front panels, especially when I touch them. I suspect this might be due to improper grounding. (NO HUM OR NOISES)
- Should I ground the chassis of each component? If so, how should I do it?
- Would replacing the power cables with grounded (three-prong) cables help? If so, where exactly should I connect the ground wire—directly to the chassis?
- What’s the recommended way to properly ground these vintage units?
