Mike Massa
I have acquired a pristine set of Infinity Primus 250 loudspeakers, that are basically a two-way setup. I've read that a common problem with the tweeters is that they can blow quite easily. I want to protect these tweeters and would like anyone's input on a possible resistive L-pad configuration (maybe 5 ohms in series and then a maybe 15 ohm across the tweeter?) or maybe a 12V automotive bulb in series with the tweeter, etc. Any ideas are welcome, thank you!
