I have an old 600-T (SN 26346F, hidden door, ...) that I'm trying to get working for a friend.
I replaced some caps on the high level amp board P1096.
I replaced the 1000uF caps (c34,c35) and 220uF caps (c32,c33) on the primary side of the interstage transformers.
I can inject a sine wave on AUX lo and get about 46Vpp on an 8R speaker load. This seems like plenty of gain.
DC Offset (no signal, 8 ohm load)
Right channel: 445mV
Left channel: 170mV
I have not adjusted the bias (not really sure how to do that).
Can I adjust the bias to help reduce the DC offset?
no diff pairs like more modern line stage boards.
here is the line stage
voltages seem ok at the output to the drivers.
2k: L -20.13V, R -19.75V
I had it on a DBT but these voltages are at house voltage (120Vac).
Any ideas? I have a scope, function generator, a few DVMs.
Thanks in advance!
Left channel: 170mV
Thanks in advance!
