how to replace binding posts on Amp?
david1909
I have a Onkyo M5060R and it has the original binding posts (BP) which do not accept banana plugs and even bare wire is tricky to screw on. I would like to replace them. I have never done this and looking for advice on "how to" and "what kind" of BP should i get?
I would concentrate on using your existing binding posts. I have found that that if you prepare the speaker wires correctly/carefully this will give a better and simpler result than going through the hassle of replacing the binding posts.
If you solder "tin" the speaker wires and bend them to the correct shape it is then possible to make the connection simpler and more secure.
Anyway, once done, it is not something that you should need to be repeating?
As a postscript I have never been keen on banana plugs as an alternative to screw up connectors...
Mod?
Sometimes new/better binding posts can be fitted into the holes vacated by the originals. Sometimes a piece of polycarbonate or acrylic can be attached to the case for mounting the new binding posts. It's really not that hard. Can you post pics of the stock terminals from inside and the backside of the amp?
You beat me to it. McMaster - Carr is a good source for sheets of plastic to use if you have to make a block to mount the terminals in. Parts Express has some nice terminals. Make sure whatever plastic you choose, it's machine-able. Some plastics melt when you try to saw them with anything but a hand saw, and the cut closes up in back of the blade. I used Delrin, and it did that. Had to use a hand saw to cut it. It drilled ok, though.
Those binding posts look fine to me. Instead, buy the matching size of spade connectors and some heatshrink, and put that on your speaker wire.
Hard to tell from the pics but those terminals look like the ones that were originally on my Yammie MX-830. There is a small hole/slot you put a straightened piece of wire into and tighten down on it. If that's right, spades won't fit.
Hey david1909, are you sure single banana plugs won't fit into those holes in the center of the posts?
Looks like those are the kind where banana plugs don't work in the holes, I've never understood those... looks easy enough to put new posts in, just make sure they are insulated, or smaller diameter and use an adaptor plate.
Thanks for you commnets RickeyM, yea i tried a couple different banana plugs and nothing fits. With the posted pics above of the inside, it does not look like this should be a difficult upgrade.
BTW..RICKEYM is this your amp? if so how do you like it?
