How to restore an old tube amplifier ?
TrevorBarten
Well-Known Member
So I have quite a few old tube amps (mostly philips) however they are all mostly original (inside) and while most of them do work I feel like I should try and get them to sound as good as possible. So what should I do ?
Just replace the old stock (50+ year old) capacitors and any out-of-tolerance resistors. Tubes last longer than expected nowadays but they are usually still good as long as they are not shorted or the glass bulb isn't cracked or broken.
Pics?
Pics?
I needed one to test some 800 ohm speakers I recently bought so I have a couple on hand atm here is a pic of 2 of the philips amps IMG_20190510_165518.jpg
I have quite a few more if I recall correctly I have 2x ag 9013 2x ag 9014 1x ag 9015 1x ag 9016 2x ag 9018 a full set of hf 309 mono blocks (2 mono amps pre amp tuner) 6400s ag 9006 etc
Oh, Phillips BiAmpli stuff. Yeah, no output trafo on those. Its a fairly interesting arrangement thats basically a cathode follower circuit. I have a tabletop radio that used those speakers, unfortunately the 6x9 was dead. I ended up subbing a normal one along with a transformer for a PA speaker to make it go.
