dewickt said:I use the 80x40x30x20@525V slightly shorter, tie the 30 and 80 together and use as 80, 20 for the 15, 40 for the 35. If you do not plan on using a C8 preamp and leave the socket unused take the 20uF sections and tie them together.
batman said:Thanks LN,
You did a great job utilizing the old cans and keeping the original look. I thought the cans were rivetted into the chassis. What did you replace the selenium rectifier with?
Levi
6) Not cost effective on a small scale.batman said:Hi All,
It was brought to my attention regarding non-existent rebuild kit for the MC-60 (?). I wonder why many repair shops do not provide such kit(s):
1) Is it about safety and reliability?
2) Potential loss of business opportunity? Parts are easily available on web and shops makes less$ on parts?
3) Rebuild kit not for DIY?
4) Repair shops don't bother since it will make it too easy? Goto step 2.
5) There are better McInstosh amps out there worth the time and money.
Hmmm...
dewickt said:I can give lots of hints on what to do, but the actual mechanics of the job are something that is hard to tell a person.
mc dan said:I have used the rebuild kits from VTV. The MC-30 kits included all the signal caps (IC), and key resistors. New diodes for bias. Do what Terry says about replacing the bias resistor.
They do have a kit for the 60's as well.
