How to set power supply voltages on SA-9500?
jackson
AK Subscriber
Hey Guys, My SA-9500 has two trimmers on the PS board. The service manual in HIFI engine does not contain the instructions for setting the voltages. I assume that's what they are for, like a SX-1250. Seems to be several revisions of the SA-9500 even before they went to MK II. Thanks Jackson
Look on the back panel and see if there is a Round label. In the label will be either KCU (Single Voltage 120V US & CAN), GN (Single Voltage 220V Sweden, Denmark, Norway, &Finland ) or D (General Export 120,220,240 V Model). The Owners and Service Manuals are for the KCU version. You need a "D" version set of manuals. Unless someone here has a "D" model configured for 120V you'll have to find the manual or a Tech that knows his way around the switches and the transformer.
AWR-075 or AWR-090
Red dmm lead to pin 7, black dmm lead to pin 10
adjust VR1 for a reading of +48.0 volts
on the component side, vr1 is FURTHEST from terminals 11 through 18
Red dmm lead to pin 6, black dmm lead to pin 10
adjust VR2 for a reading of -48.0 volts
on the component side, vr2 is CLOSEST to terminals 11 through 18
Thanks!
AWR-075 or AWR-090
Thanks!
