since you intend to have this for a long time. do your homework, listen to the best, and
be careful about following flipper moves that can and will destroy things.
1. compare the service manual schematics, to the parts lists, the PCB stencilling,
and above all, the working active/passive components on the board. do not assume
the schematics, the stenciling, the parts lists are complete, or accurate.
2. do your own parts lists. others' mistakes can be yours. then with the list
you can upgrade specs, combine qtys for bigger discount (and to be able to measure
to get tighter tolerances), and to upgrade (research the pecking order and move
up the "food" chain for better sonic results) to better caps.
3. do not begin your journey (soldering, upgrades, etc) on these units, buy crap
unit off ebay/CL/etc and start learning on them. learn reflowing joints, pulling
components, cleaning lands, prepping for soldering, use of flux, cleaners, etc
and if you really care, learn to read schematics, troubleshoot, re-engineer but
this is a long pole effort...
4. always, always: in replacing a part, pull old, measure old, compare to verified
parts list, PCB layout, and schematic. then measure replacement, solder in,
mark on all documents the change made. fail to do this and with 200 caps, resistors
changed, all it takes is ONE to screw things up and if you skipped the step about
reading the schematics you may never find the problem and may have to pay $100+/hour
to have somone one else do so. troubleshooting is a whole new universe.
5. DBT
6. caps from one vendor? there are galactic battles over caps. Black Gates, Silmic II
silk caps, Russian teflons, Green Nichicon MUSE ES non-polars, small value c0g,
silver micas, polypropylenes in the PS,... not possible for the ultimate sonics no
matter how narrowly or broadly accepted/argued/defined/etc. that's just caps
how about thin/thick film resistors, 0.1% ones, allen-bradleys from 50 years ago,
special Japanese black cylindricals, takmans, Vishay-dales, etc.
the good news is that you will be refreshing 40+ YO gear, which is good on a
number of levels: it will last longer, you avoid the periodic teardown to find
yet another 40 YO failure, and the sonics will be great.
then every so often in the next 50 years, if anything happens, you can go in and
fix things. (I have this hafler preamp bought about 40 years ago, in great
operational conditions with great sonics that I've upgraded/fixed twice). and if
there's some breakthrough you can go in and upgrade.
not to mention bragging rights, street creds, and if you document this and want to
sell, you will get about double what the flippers get with their banged up, dead units.
and if you post here, you help others with your work, and with what you learned,
you go onto bigger and better things as you enjoy the music.
