HPM-100 Modification Help Needed - Completed
dminches
Member
I would like to replace the stock tweeter and midrange drivers in the HPM-100 with drivers from a DSS-9.
First, the hole offsets for both are different than the current ones. What should I use for new screws? The current ones screw into a nut which I think is buried inside the speaker case. Should I drill new holes and use a self-setting screw or should I glue nuts on the inside of the case at the back of the new hole?
Second, the I need to make the midrange hole larger to fit the DSS-9 driver. How should I do this?
I contemplated this change at one time. You can have an adaptor made to account for the screw hole offsets. A thin, circular adaptor with holes drilled for the HPM-100 pattern and holes drilled and tapped for the DSS-9 pattern. As for the midrange hole, I think a little judicious filing would probably work. I decided not to modify my cabs, and used tweets and mids from the S-910. They're mostly a drop in fit. The tweeters need to be tweaked a little if I remember right. Sounds smoother than stock (not as shrill), but I still use an equalizer to tone down the HPM-100s.
Wow, I just read this and had to look the speakers up. You should hear a vast improvement with the upgraded mids and ribbon tweets. Would like to hear those!
I'm a fan of properly executed ribbons. I want to do a DIY build using ribbons...seen a project that looks really nice: http://projectgallery.parts-express.com/uncategorized/vultus/ NOT the bass extension you get, but with a stand alone sub, should sound real accurate.
I finished this over the weekend and I am very happy with how the speakers sound:
that's interesting. I just scored a pair that need a little work. Can you describe how the improvements sound? I wonder if I'd notice the difference in my space, it's a bit cluttered since it's a workshop
The drivers are an upgrade from the stock 100s. The tweeter is less harsh sounding and the midrange provides a nicer soundstage as well as more detail.
Looks great. I'll admit, I kind of cringed a little when you drilled into the actual cabinet, but it was for the best. Awesome work, dminches.
Since HPM and DSS have different crossoverpoints, did you change anything ore recapped in the crossover?
The crossover points between the midrange and tweeter are the same. The crossover between the mid and woofer are different but I haven't changed that since I have the original woofer.
How do they sound to you? You did a great job; they look like they left the store with those speakers installed. Very impressed!
I think they sound great. I still need to get stands but I listened to a live Allman Brothers recordings and the imaging and soundstage were great.
What is the reason for this improvement? Are the stock units inferior? Sorry for the newbie question but I always assumed the HPM100 was a great speaker as is..............
The HPM-100s are excellent sounding speakers, but this is the world of audio where we always try to tweak out a little more quality.
Personal opinion - while I liked the HPM-100 when I owned them, the tweeter is the weak link in that speaker, for sure. Replacing it with the extraordinarily good ribbon tweeter from the DSS-9 would have to be a huge improvement. I replaced the 100's tweeter with the ribbon from a Pioneer CS-901, and that was a big improvement, but the DSS-9 ribbon tweeter is much nicer still. The mid would just be icing on the cake.
